Was wat aan het zoeken op pubmed en kwam deze studie tegen
http://www.ncbi.nlm.nih.gov/pubmed/11428691" onclick="window.open(this.href);return false;
waarvan de samenvatting:
Uit dit artikel haal ik dat de grootste verschillen zitten in training (uiteraard) en houding op de fiets. Het artikel gaat verder niet in op specifieke onderdelen, behalve dan het frame en de wielen.Cycling performance is dependent on physiological factors which influence mechanical power production and mechanical and environmental factors that affect power demand. The purpose of this review was to summarize these factors and to rank them in order of importance. We used a model by Martin et al. to express all performance changes as changes in 40 km time trial performance. We modelled the performance of riders with different ability ranging from novice to elite cyclists. Training is a first and most obvious way to improve power production and was predicted to have the potential to improve 40 km time trial performance by 1 to 10% (1 to 7 minutes). The model also predicts that altitude training per se can cause a further improvement of 23 to 34 seconds. Carbohydrate-electrolyte drinks may decrease 40 km time by 32 to 42 seconds. Relatively low doses of caffeine may improve 40 km time trial performance by 55 to 84 seconds. Another way of improving time trial performance is by reducing the power demand of riding at a certain velocity. Riding with hands on the brake hoods would improve aerodynamics and increase performance time by approximately 5 to 7 minutes and riding with hands on the handlebar drops would increase performance time by 2 to 3 minutes compared with a baseline position (elbows on time trail handle bars). Conversely, riding with a carefully optimised position could decrease performance time by 2 to 2.5 minutes. An aerodynamic frame saved the modelled riders 1:17 to 1:44 min:sec. Furthermore, compared with a conventional wheel set, an aerodynamic wheel set may improve time trial performance time by 60 to 82 seconds. From the analysis in this article it becomes clear that novice cyclists can benefit more from the suggested alterations in position, equipment, nutrition and training compared with elite cyclists. Training seems to be the most important factor, but sometimes large improvements can be made by relatively small changes in body position. More expensive options of performance improvement include altitude training and modifications of equipment (light and aerodynamic bicycle and wheels). Depending on the availability of time and financial resources cyclists have to make decisions about how to achieve their performance improvements. The data presented here may provide a guideline to help make such decisions.
Zijn er mensen die iets meer kunnen zeggen over wat de verschillen zijn als je kijkt naar bijvoorbeeld versleten/nieuwe ketting, soorten banden, kwaliteit derailleur, etc? Eigenlijk zou je bij de aanschaf van al die onderdelen wel ongeveer willen weten wat het uitmaakt. Geef je 500 euro uit voor een setje wielen waarmee je 1,5 km/u harder fietst, of geef je 25 euro uit voor een nieuwe ketting zodat je 1 km/u harder fietst bij hetzelfde vermogen?
En als er geen daadwerkelijke metingen bekend zijn, wat schatten jullie dan zelf in? Wat zijn de onderdelen die het meest verschil maken en hoeveel?
