Een update beschikbaar:
Changes from version 2.10 to version 2.20:
Added setting to turn on 1 second recording in Settings > System > Data Recording.
Fixed an issue that could cause large jumps in position and distance.
Added Last Lap Power data field.
Fixed an issue that was causing ANT sensors to not pair as expected.
Added a setting to enable a prompt to recalculate during navigation.
Courses are now usable with GPS turned Off and a connected ANT Speed sensor.
The Virtual Partner can now be manually synchronized by pressing and holding on the Virtual Partner graphic.
Fixed a speed zone field display issue.
Improved course navigation.
Fixed issues viewing an activity in progress from the history menu.
Fixed issue with some Mac users not being able to connect to device without resetting the timer.
Fixed some display issues when using a weight scale.
Fixed an issue that could cause distance to not accumulating after switching bike profiles while the timer is running.
Fixed a few issues while editing workouts and a display issue while doing a workout in night mode.
Fixed a display issue while doing a workout in night mode.
Improved elevation calibration when manually setting device elevation.
Changes from version 2.00 to version 2.10:
Improved Auto Pause behavior.
Corrected issues that could cause incorrect speeds to be recorded.
Improved auto wheel calibration especially for PowerTap power meters.
Added a torque reading to the calibration page for Powertap power meters.
Removed DeleteFiles folder.
Allow the device to operate in normal mode with external power.
Corrected issues that could corrupt activity files which would not allow them to be uploaded to Garmin Connect or Garmin Training Center.
Improved keyboard layout, input, and design.
Made improvements to the elevation profile.
Added an activity reset reminder.
Improved how the device responds when the screen has been locked.
Added a factory default reset in MENU -> Settings -> System -> Initial Setup.
Added the ability to view details for an activity that has not been reset.
Data fields should now report correct time and distance while navigating.
Corrected issues caused by removing an SD card while navigating.
Corrected Auto Scroll issues.
Corrected issues drawing the current activity on raster maps.
Made improvements to the Virtual Partner.
Added memory full warning message.
Corrected issue that could prevent activities from being able to be deleted.
Route recalculation can now be turned off in MENU -> Settings -> System -> Routing -> Recalculate.
Added a day/night color mode setting in MENU -> Settings -> System -> Display -> Color Mode.
Sensor settings will now be correctly maintained when merging FIT setting and sport files.
Corrected issues with weight scale data recording and communication.
Corrected issue that could cause lap calories to be reset after a power cycle.
Corrected issue that could cause workouts, courses, and locations to not be displayed in their respective lists.
Corrected issue that could cause data field changes on the map or elevation training pages to not be saved.
Lap markers in a course will now be recorded correctly while following the course.
Update 2.2 Garmin Edge 800
tomkolkman
Dit had ik ook al in het Edge 800 topic gepost, wat mij betreft is het daar beter op zijn plek.
Ik had nog wel last van meer veranderingen, hartslag zones, virtuele partner, kaartgegevens.
Cannondale SuperSix EVO Hi-Mod
Cervélo R3SL
BMC CX02
Cervélo R3SL
BMC CX02
Toch weer een paar details die verbeterd werden (en waar ik inderdaad al last van gehad heb).
trek x 500 2008
red bull pro sl ultegra 2010
rose trekking multisport 2011
https://picasaweb.google.com/picomadone/" onclick="window.open(this.href);return false;
