Squadrats
Gisteren mijn hoogste op een normale manier te halen übersquadratinho ten oosten van de Maas in Maastricht gehaald. In het westelijk deel van de stad is meer mogelijk (spoorwegemplacement en Maasplassen liggen in de weg)
Übersquadratinho:
Willem Altes.....................................29 x 29
TMK..................................................27 x 27
Willem12..........................................23 x 23
Rhino7/2...........................................16 x 16
BertL.................................................15 x 15
Anneroel...........................................13 x 13
ultra_ivo...........................................13 x 13
Globeskater......................................12 X 12
lnnrtlnnrt..........................................12 x 12
Raassie..............................................12 x 12
Freek053..........................................11 x 11
McMiGHtY.........................................11 x 11
Sulla................................................. 10 x 10
WDFL................................................. 9 x 9
Yardinho:
Willem Altes..................................33777
Willem12.........................................5153
TMK.................................................3835
Anneroel..........................................1689
Rhino7/2...........................................1326
BertL................................................ 1311
Freek053...........................................844
Sulla...................................................731
ultra_ivo............................................678
WDFL ................................................526
Globeskater.......................................482
Raassie..............................................434
lnnrtlnnrt...........................................393
McMiGHtY..........................................263
Squadratinhos:
ultra_ivo.........................................538865
Rhino7/2........................................224471
Willem12........................................204970
BertL...............................................172517
Globeskater....................................153383
Willem Altes...................................144663
Anneroel.........................................144213
lnnrtlnnrt..........................................100011
TMK..................................................78458
McMiGHtY.........................................75249
WDFL................................................52918
Raassie..............................................52324
Freek053..........................................50181
Sulla..................................................38776
Übersquadratinho:
Yardinho:
Squadratinhos:
Übersquadratinho:
Yardinho:
Freek053...........................................856
Squadratinhos:
Freek053..........................................50303
Afgelopen weekend weer een paar blokjes ingevuld
Yardinho:
Squadratinhos:
I refuse to join any club that would have me as a member
Willem Altes
Mijn Yardinho zit nu boven de 35 duizend. Gisteren nog tussen de kassen en langs de veiling in Honselersdijk in het Westland het tuintje naar Naaldwijk uitgebreid.
Übersquadratinho:
Yardinho:
Willem Altes..................................35149
Squadratinhos:
Willem Altes...................................146786
lnnrtlnnrt.........................................100011
Übersquadratinho:
Yardinho:
Squadratinhos:
- Globeskater1983
@willem zijn de squadratinhos rond het huis van de koning te bereiken?
Übersquadratinho:
Yardinho:
Globeskater.......................................494
Squadratinhos:
Globeskater....................................153878
Übersquadratinho:
Yardinho:
Squadratinhos:
Welk 'huis' van Willy bedoel je precies?Globeskater1983 schreef: ↑03 mar 2025 10:07 @willem zijn de squadratinhos rond het huis van de koning te bereiken?
Als je 'Huis Ten Bosch' in Den Haag bedoelt wordt het lastig.
Er is één tegel aan de zuid-oostkant die volgens mijn totaal niet bereikbaar is.
De tegel bij de hoofdingang (noord-west) is volgens mij wel net te doen. Je kunt daar (zeker als je een klein kind bij je hebt) iig helemaal doorlopen tot op het hek zonder rare blikken van de beveiliging.
De meest noord-oostelijke tegel kan je doen via de tuin van Résidence Chateau Bleu. Wellicht dat je even de huismeester moet uitleggen wat je komt doen. Zou iig niet naast de residence door het bos gaan lopen banjeren buiten de paden.
Mocht je de oude boerderij (Eikenhorst) op de Horsten bedoelen, daar ga ik binnenkort wandelen met mijn moeder (77) die daar zo'n 65 jaar geleden kind aan huis was. Dus daar kan ik je dan evt meer over vertellen, maar volgens mij wordt dat nu verhuurd aan een privé persoon, eoa ondernemer, dus daar zal ook nog steeds een flink hek omheen staan.
- Globeskater1983
@Sulla,
Ik woon vlakbij Huis ten Bosch
dus bedoelde die. Ik ga eens kijken of dat met de kleine man als die zover met zijn loopfiets kan een keer te doen is.
Gewoon de Garmin op zijn loopfiets zetten en hem heel hard langs de bewaking laten crossenGlobeskater1983 schreef: ↑04 mar 2025 12:37 @Sulla,
Ik woon vlakbij Huis ten Boschdus bedoelde die. Ik ga eens kijken of dat met de kleine man als die zover met zijn loopfiets kan een keer te doen is.
En daarna de geshockeerde ouder spelen "doet ie anders nooit hoor"
Übersquadratinho:
Yardinho:
Squadratinhos:
Freek053..........................................50527
Yardinho:
Squadratinhos:
Übersquadratinho:
BertL.................................................16 x 16
Yardinho:
BertL................................................ 1326
Squadratinhos:
BertL...............................................173548
Jaardoel: Rhino7/2 voorbij steken.
Yardinho:
Squadratinhos:
hun fietsen.
Übersquadratinho:
Yardinho:
ultra_ivo............................................ 770
Squadratinhos:
ultra_ivo.........................................543682
Yardinho:
Squadratinhos:
lnnrtlnnrt
Vanmorgen het laatste vakje in de binnenstad van Zwolle 'dichtgerend', nu alle wijken nog.
Übersquadratinho:
Yardinho:
lnnrtlnnrt...........................................465
Squadratinhos:
lnnrtlnnrt.........................................101206
Übersquadratinho:
Yardinho:
Squadratinhos:
Afgelopen weekend wat lokale gaatjes dichtgereden en Yardinho over de 1000. Ik sta er trouwens best van te kijken hoe lastig het soms is (zelfs in de aan één gebouwde randstad) om bepaalde dorpen/plaatsen (qua cluster/yardinho) aan elkaar te fietsen.
Übersquadratinho:
Sulla................................................. 11 x 11
Yardinho:
Sulla...................................................1090
Squadratinhos:
Sulla..................................................39490
Übersquadratinho:
Yardinho:
Squadratinhos:
