ultra_ivo
ultra_ivo 21 nov 2024 23:21
BertL schreef: 21 nov 2024 23:01 Dan wordt het GPX-bestand omgezet van het ene dialect in het andere waardoor Strava het vanuit Etrex niet verwerkt wordt en via Garmin Connect wel.
Eerst wel, daarna niet. Ergens halverwege dit jaar heeft Strava kennelijk wat omgezet, waardoor een met dezelfde programma's/GPS gegenereerde GPX tracks eerst wel en daarna niet meer gelezen konden worden.
DDX 21 nov 2024 23:23
Wandrer heeft update gepost :
https://www.strava.com/clubs/528504/posts/33606187
Hey folks -- got some things cleared up with Strava today, and it's about what we expected. They had two requests:
* Leaderboards should be opt-in by default for new wandrers. Ok, not a big deal.
* Wandrer maps should not be visible to other users. This is what took some back and forth with Strava's legal team because the change to Strava's API terms specifically covers the visibility of "Strava data", which is also defined in their terms as data originating from a Strava API endpoint. My pushback on this is that no data that originates from Strava is visible or accessible on your map: it's all drawn from OpenStreetMap geometries, and Strava data definitely informs the boundaries of those geometries, but only after it's gone through Wandrer's algorithms and datasets, and not in a way that identifies time or frequency of travel on a road. I don't think it's fair to call Wandrer's data "Strava data", but anyways.
The only options Strava sees going forward for sharing your map is that the user has something where they could export an image of their map, or maybe generate a one-time link that someone could use to view their map. Neither of those feel like great options to me. My proposal of "let people decide if they want their map visible to others, with a check-in pop-up every few months for those who have publicly-visible maps" was not accepted.
I know many of you love sharing your map and looking at other peoples' maps (I do, for sure), so I'm going to provide an option for you to be able to keep doing that going forward: getting your data in to Wandrer through some place other than Strava. If you don't care about other folks being able to see your map, you can just stay where you are.
I'll have a longer blog post with more details as we get those worked out, but I can tell you a few things right now:
* I'm still devoted to working on Wandrer and getting new features and updates out to you (there's new map data available as of last night)
* There will be alternative methods of getting data in to Wandrer if you want. If you have any services that you'd especially like Wandrer to work with, let me know.
* Nothing will change with your data visibility until mid December.
1094
1094 22 nov 2024 08:14
Intervals.icu blijft ook gewoon werken lees ik.
0475
0475 22 nov 2024 09:50
Als Strava hiermee weg komt dan zie ik anderen zoals Garmin, Wahoo, Komoot, etc ook wel volgen, the battle for the data. Dan zul je misschien ook nog gaan krijgen dat op nieuwe apparaten of na firmware updates de .gpx/.fit data is versleuteld zodat je het nergens elders naar kunt uploaden dan op het platform van de maker van je apparaat.
wasbeer2006 22 nov 2024 11:14
Dat is het hele punt data en het gemak waarmee we alles zomaar overal neer gooien.
Nu is het strava en onderschat de waarde van die gegevens ook niet voor bv zorgverzekeraars/hypotheek verstrekkers.
DDX 22 nov 2024 11:51
Goed blog artikel van Arnoud Engelfriet dat aanpassing van strava waarschijnlijk in strijd is met de AVG :
https://blog.iusmentis.com/2024/11/22/s ... an-de-avg/
Gebruikersavatar havana 22 nov 2024 12:06
Ik denk dat het veilig is om te veronderstellen dat Strava behoorlijk geschrokken is van alle reacties.
koeroeur
Gebruikersavatar koeroeur 22 nov 2024 12:16
Ze zijn heel hardleers blijkbaar...
Het is moeilijk om weg te gaan van Strava omdat veel users data van jaren ver bij hen hebben. Plus de opgebouwde contacten. Daarom blijf je meestal.
Maar je kan ook te ver gaan à la X. Daar is nu blijkbaar echt een leegloop bezig?
Ik was al geen twitteraar maar heb ook m'n X account stopgezet zodra Elon het als z'n persoonlijk speelgoedje begon beschouwen. Freedom of speech zolang het hem uitkomt.
ultra_ivo
ultra_ivo 22 nov 2024 12:23
koeroeur schreef: 22 nov 2024 12:16 Ze zijn heel hardleers blijkbaar...
Je kunt ook je masterdata in je eigen PC bijhouden zodat je relatief makkelijk kunt weggaan. En, conform de AVG, moet Strava je ook je geuploade data terug geven.
Ik heb altijd mijn GPS gegevens zelf bijgehouden. In het verleden na iedere rit van de Etrex gedownload, tegenwoordig om de zoveel tijd (ik gebruik tegenwoordig naast elkaar een Edge en een Etrex). Dus mocht ik naar een ander willen, geen punt. Het zou me alleen een paar avonden uploaden kosten.
Dus mijn tip: je Strava data regelmatig downloaden zodat je een eigen off-line kopie hebt.
DDX 22 nov 2024 13:08
Ik denk dat die leegloop wel meevalt, tuurlijk zullen er mensen weg gaan.
Maar er zijn ook mensen die dat aleen roepen.
En merendeel blijft gewoon lekker op strava want een echt alternatief is er niet.
En voor veel mensen zal er niets veranderen.
BertL
Gebruikersavatar BertL 22 nov 2024 13:17
Daar komt een oplossing voor. Wij kunnen elkaar ook bellen als jij een Siemens telefoon hebt en ik een Nokia. En je kunt elkaar ook mailen als jij bij Ziggo zit en ik bij KPN.
Die uitwisselbaarheid wordt als eerste geregeld bij de berichten apps, zodat je onderling berichten kunt uitwisselen tussen Whatsapp, Telegram en Signal.
hun fietsen.
Gebruikersavatar daniel1975 22 nov 2024 13:19
Ik lees alleen nog, maar wordt steeds minder interessant. Ik heb Musk sowiso geblokt, ik kreeg allemaal tweets van hem in mijn timeline. Gevaarlijk dat hele rijke mensen zoveel macht hebben over de media.
