heb het forum niet door gespit maar beter dubbel gepost dan niet:
RECALL van CERVELO 2.5
Cervélo has identified a potential safety issue involving the down tube loosening or separating from the head tube on some R2.5 frames. Therefore, Cervélo Cycles is voluntarily recalling a limited number of 2005 model year R2.5 carbon bicycle frames.Although the 2005 R2.5 carbon road frame passed all the standard industry frame tests, this particular problem was not uncovered during those standard frame tests. Cervélo has now discontinued the R2.5 model. The currently produced carbon road frames do not use the same lug design and are not susceptible to this problem.This recall only applies to 2005 R2.5 road frames with serial numbers greater than R251700. These frames could have been purchased as a frameset or built with Shimano DuraAce (red decals) or Campagnolo Chorus (blue decals). All affected R2.5’s have clear coating over carbon fiber – see photo’s along the left of your screen. If you purchased a 2005 R2.5, and have since sold it or given it away, please email the recall coordinator at color=#0000ffrecall@cervelo.com as soon as possible with the name, phone number, email address and or full mailing address (or any and all contact information you have) of the person who purchased the frame from you, so Cervélo can inform them of the recall process. Please share this notice and website with all your riding friends or bike club.
Cervélo
ilfalco2004
Fly like an Eagle!
Old Warriors Never Die
Mooi niet, volgens mij krijgt de eerste eigenaar een R3 terug (bijbetaling??). Alle overige frames worden volgens mij omgeruild voor een 2.5 die ook gewoon weer op de markt is. Overigens heb ik vier 2.5 frames afgebouwd en hebben ze allemaal de geest gegeven dus helemaal onterecht is de terugroepactie niet.
Van het WW forum:
After you fill in an affected serial number this will appear...:
Quote:
The free replacement frame will be a 2006/7 Cervélo R3. Alternatively, you may upgrade your replacement frame to a new 2006/7 Soloist Carbon for a charge of $300.00 USD. Both the R3 and the SLC will come with a new seatposts, the FSA SLK 32.4mm or Cervélo aero carbon - 1-position, respectively. All other parts from your recalled R2.5, including fork, headset and bottom bracket will be built onto the new replacement frame. Dus de 2.5 wordt gratis omgeruild voor een r3. Voor een Solist carbon moet je 300 dollar bijbetalen.
Een dag niet gefietst is een dag niet geleefd...
Laat ik nu nét een r 2.5 gekocht hebben, nummer is alleen lager dan de nummers die terug gehaald worden.
ilfalco2004
Salden heeft er nog 3 geloof ik zal toch eens stiekuhm naar de nummers kijken..... r2.5 kopen voor 1350 en R3 er voor terug krijgen.
Fly like an Eagle!
bike_add1ct
Hee mijn quotes zijn copyrighted Jorrit...
Heeft iemand (sharkman?) trouwens enig idee wat er verandert is aan het productieproces bij Cervélo wat sommige R2.5's wel veilig moet maken?
Quoten: Origineel geplaatst door Hanz op 04 Oktober 2006
Die R2.5 is niet weer in het productieproces opgenomen. Dat zijn dus oude modellen.
Verschillen tussen R3.0 en 2,5 zijn gewoon veel.
Van de 10 door ons verkocht is er 1 retour gegaan en die man heeft zonder bij te betalen een R3 gekregen van Cervelo Bij Cervelo heeft alleen eerste eigenaar levenslange garantie.
wie is dat/ zijn dat ?
Lijkt me duidelijk.....
En hij rijdt heerlijk moet ik zeggen !!
