Shimano Ultegra/Dura-Ace Di2 12-speed
Kopie uit een interview dat ik toevallig net zit te lezen. Nog weinig nieuws over tijdlijn.
What can we expect from 2022? Will there be a 105 Di2? Will mechanical shifting start with Tiagra?
“Currently I don’t believe there will be a 105 Di2. But I would be really surprised if Shimano aren’t looking into it heavily,” says Mike Anderson, PR manager of Shimano’s UK distributor Madison.
He explains that historically the Ultegra and Dura-Ace electronic groupsets are produced in a different facility from the rest of the road groupsets, meaning a significantly larger production would be expected from a factory not equipped for that scale.
“All the Di2 is produced in high-tech clean rooms because you don’t want contamination of any of the electrical components, microchips etc. so that has always been the barrier,” says Anderson.
There’s also profit margins to consider, as Anderson explains: “105 is specced on a huge number of bikes from £1,500 up to £2,800 so you’d need to manufacture it in a huge quantity and still make some money given that you would have to develop the ability to make the wireless tech cheaper.”
There’s also the tooling for aluminium rather than carbon to consider: Anderson notes that since 105 is all alloy rather than carbon there would be a lot of setting up to be done.
“At the moment the quality of Shimano 105 relative to the price is astonishing,” he says. “Maybe more likely is that Shimano are working on 12-speed mechanical for 105. Because the change from a ratchet that shifts 11 times to a ratchet that shifts 12 times is not as significant as trying to rework the whole groupset as electronic.”
Ik pak ze wel weer in de afdaling
De laatste alinea. Vroeger maakte ze andere ratchets voor gripshift zodat je met andere derrie's kon rijden.
Volgens mij wordt dat nu nog gedaan voor roadshifters en komt dit juist weer terug door te gravelhype en het monteren van andere derrie's dan bij de groepen hoort. Je kan dan dus zelf gewoon je shifter aanpassen.
tom de groot
Ga er maar vanuit dat die di2 105 wel komt net als een graven di2 12 speed. Een kwestie van tijd.
Het zou mogelijk moeten zijn om DI2 zo te programmeren dat 10 en 11 speed ook te schakelen zijn. Dat niet aanbieden is meer een commerciele dan een technische keuze.
Ik schat dat een 12 speed mechanische groep de nieuwe 105 zou kunnen worden. Prijsverschil naar electronisch is nog steeds een echte stap.
Aangezien de shifter bij het bedienen van de schakelknop steeds dezelfde schakelcode uitstuurt hoef je m.i. DI2 niet te programmeren dat het 10 of 11 of 12 speed moet zijn.! Mits het hetzelfde bus-systeem is natuurlijk.
Zou wel willen weten of de nieuwe disc remklauw compatibel is met de vorige serie (zou een welkome upgrade zijn).
Edit----
Om mijn eigen vraag te beantwoorden: Ja, zie de compatibility matrix:
https://productinfo.shimano.com/#/com?c ... acid=C-456
Edit----
Gazelle Trendy 7 speed, RVS velgen
Gehoord in de laatste podcasts van Fiets.nl dat de levering van november uitgesteld werd naar ten vroegste april volgend jaar?
(Eigenaar Math Salden tijdens de podcast)
[quote=Kiekeboe post_id=1500718 time=1635257381 user_id=415273]
"de" levering.
de levering van wat?
losse groepen - onderdelen 12sp - complete fietsen dat Salden verkoopt met nieuwe 12sp groepen?
[/quote]
Excuses, leveringen van groupsets idd
"de" levering.
[/quote]
Helder. Wat nu beschikbaar is/komt gaat dus naar de grote afnemers die er hun voorjaarsvoorraad 2022 mee kunnen gaan afmonteren. Upgraden op je huidige fiets (als je Shimano wilt) gaat gewoon niet gebeuren voor zomer 2022.
Is dat bij Shimano ooit anders geweest? Laatste keer XTR duurde het volgens mij ook bijna een jaar na de introductie.
SRAM doet dat toch een stuk beter, die zorgen dat er op het moment van intro in elk geval een basisvoorraadje ligt.
