Het dopingtopic 2.0
- MarkVeenstra
Die Santaromita was zeker een pannenkoek.., maar 3.6 punten winst....
Heb toch altijd gedacht dat die Shamal wielen het verschil maakten...
Voor diegene die Netflix kunnen bekijken:
sinds dit weekeinde staat Icarus er op.
Moeite van het kijken waard vond ik.
Dit is de officiële trailer:
https://www.youtube.com/watch?v=qXoRdSTrR-4
Allard
Samuel Sánchez is tijdens een out-of-competition test op 9 augustus betrapt op doping. De 39-jarige Spanjaard van BMC had sporen van het groeihormoon GHRP-2 in zijn bloed. Dat maakt de UCI vandaag bekend.
http://www.wielerflits.nl/nieuws/290579 ... oping.html
Sukkel
Prima spul als ik het zo lees, alleen nog zo'n gedoe dat je het moet injecteren.
HRP 2 is a popular synthetic ghrelin agonist despite being newly discovered. It provides a host of benefits such as increased production of IGF-1, better endurance, improved lipid metabolism, stronger bones and immune system, improved sexual drive and desire, and faster wound healing. Moreover, it has cardioprotective properties making it a very potent peptide.
What does GHRP means?
Growth hormone releasing peptides also known as GHRPs, are a family of peptides that acts on the hypothalamus and pituitary gland to release growth hormones through activating a particular protein receptor. This peptide family was first identified two decades ago as a laboratory made metenkephalin derived oligopeptides, simply put it, a synthetic tissue from amino compoundss. Note that GHRPs have no structural similarity with your natural growth hormone releasing hormone (GHRH). Clinical studies however revealed that GHRPs acts instead on the pituitary to produce HGH or human growth hormone.
What is GHRP 2?
Growth hormone releasing peptide 2 or GHRP 2 is a synthetic analog of GHRP 6. It is well-known for its ability to effectively improve and stimulate the production of human growth hormone. It also plays a role as a ghrelin activator. Ghrelin is a newly discovered peptide found in the gut. It binds to growth hormone secretagogue receptors as well as promotes food and stomach emptying.
GHRP 2 is a potent hexapeptide similar to GHRP 6. It has been extensively studied for its ability as a GHS (growth hormone secretagogue) or to stimulate the production of growth hormones. It is popular for its capacity to stimulate the release of ghrelin resulting to increased appetite and hunger. This peptide is best used to correct decreased production of growth hormones. It is also able to help unusually lean individuals gain weight. It is also an excellent substance to reverse the effects of aging amongst persons with low growth hormone levels.
How does GHRP 2 works?
GHRP 2 works through stimulating the pituitary gland’s natural ability to produce endogenous human growth hormone (HGH). It enhances HGH production in two ways – first, it amplifies the transduction pathway of natural growth hormone releasing signal which lead to an increase in growth hormone levels. Second, it inhibits the activities of somatosatin thus bringing about an increase in endogenous growth hormone levels.
How should you take GHRP 2?
GHRP 2 should be taken daily via oral (sublingual), intranasal or subcutaneous (injection) routes. It may be used in conjunction with sermorellin or GHRP 6 for optimal results. Noth GHRP 6 and sermorellin helps in activating the pituitary gland enabling increased manufacturing of natural growth hormones. In addition to this, it also increases hypothalamic functioning which further help in promoting its purported benefits.
What are the benefits of GHRP 2 supplementation?
Some benefits associated with GRP 2 supplementation includes:
Improves signs and symptoms of aging such as decreasing wrinkles and improving skin elasticity.
Enhances endurance.
Promotes faster wound healing.
Protects and strengthens the heart.
Enhances sexual desire and drive through stimulating the hypothalamic area.
Improves the body’s ability to fight off diseases.
Improves energy and vitality.
Increases the production of IGF-1 in as much as 50% more in the first week of use.
Improves quality of sleep.
Promotes lipolysis.
Decreases body fat.
Increases protein synthesis.
Aides in the improvement of vision and eyesight.
Improves bone density and strengthen through increasing calcium retention and bone mineralization.
Promotes glucogenesis in the liver.
Decreases uptake of glucose in the liver.
Helps in contributing to the functioning and maintenance of the Islet of Langerhans or pancreatic islets.
Treat growth hormone deficiency.
Is it safe to use?
Numerous studies have confirmed that GHRP 2 is the safer alternative of synthetic HGH. Scientists reiterate that users are not likely to experience any undesirable effects if this specific peptide is administered within the recommended dose ranges. Using GHRP 2 in excess might cause unfavorable occurrences such as easy fatigability, increa.sed water retention and numbness or tingling in the extremities. Conclusively, we can confirm that GHRP 2 is relatively safe and less risky as compared to synthetic HGH known to produce a series of side-effects
Buy GHRP 2
In buying GHRP 2, ensure that you are aware of its possible effects, particularly the adverse events. Make sure that you buy GHRP 2 from trustworthy and respectable sellers. Precautionary measures must be exercised when taking this peptide. Individuals who are suffering from a medical condition or are taking over the counter, herbal and prescribed medications should ask for their doctor’s advice before taking GHRP 2.[/quote
colnagofreak
